Activity Forums Apple Final Cut Pro Legacy SD-DV to BetaSP, workflow /DecklinkSP ?
  • SD-DV to BetaSP, workflow /DecklinkSP ?
    Posted by Ninetto Makavejev on September 2, 2009 at 8:46 am
    Hello,
    after completing an SD-edit, the client (an art institution) has decided they want a BetaSP tape. There is little compositing, except for the subtitle graphics.
    I have access to a Decklink Blackmagic SP card with outputs for a BetaSP-deck. But would this really be better than tape, i.e.
    Would it make sense to drop the finished sequence into an uncompressed or ProRes sequence, for better quality output direct to the BetaSP deck? I beleieve I could use the SDI outputs of the Decklink card.
    Or is the quality of SD-DV so low anyway, that I could just transfer the finished edit to DV tape, and use that as the master to produce the BetaSP that the client wants?
    thankful for any advice,
    ninetto
    Rafael Amador replied 17 years ago 2 Members · 3 Replies
  • Rafael Amador
    September 2, 2009 at 12:00 pm
    Hi Ninetto,
    the quality of the DV footage can be very much improved in postproduction.
    Edit in a rendering in a sequence with a codec better than DV (at least DV50. Better Prores), Chroma Smoothing (Nattress), color Correction and “Render in high Precision”. Then print to video through a good video card. Its worth the extra work and time.
    Cheers,
    rafael
    http://www.nagavideo.com
  • Ninetto Makavejev
    September 2, 2009 at 6:54 pm
    Thanks for the info and motivation!
    I suppose the workflow is a bit backwards, but since the DV edit is done already, it is OK to just drop the finished edited DV sequence into a new ProRes sequence, and render that out as you suggested? Or do I have re-convert (via Media-Manager) or recapture the raw DV master material?
    regards,
    ninetto
  • Rafael Amador
    September 3, 2009 at 1:49 am
    Hi Ninetto,
    If the movie is already rendered and don’t think you will get any improvement converting it in Prores. Just play it through the video card.
    rafael
