Activity Forums AJA Video Systems SD animorphic to SD letterboxed-How to
  • SD animorphic to SD letterboxed-How to
    Posted by Tom Matthies on October 23, 2006 at 5:03 pm
    After reading the post below about the ability of outputting SD animorphic to SD letterboxed in one step, I downloaded and installed the new drivers. I’m in the middle of cutting a SD show in animorphic format and it would be nice to be able to ouput it without having to make a separate sequence for letterbox and render it.
    The question? Just where is the setup to change this? In looking at the easy setups, I don’t see this option. Where is it hidden? I give up.
    Now on that note, I need to rebuild my favorites folder since I forgot that loading the Kona drivers would wipe out all my preferences along with my favorites folder. Shoot!
    Now, if I could only remember where I stashed that backup copy of it…
    Tom
    Tom Matthies replied 19 years, 11 months ago 3 Members · 5 Replies
  • Tom Matthies
    October 23, 2006 at 5:23 pm
    By the way, running FCP 5.1.2 on a Quad G5 with a Kona 3 board. Trying to playback an anamorphic FCP SD sequence out thru the Kona 3 and have it letterboxed in SD out via SI to a Digibeta deck.
    Thanks again.
  • Jared Picune
    October 23, 2006 at 6:41 pm
    It’s a function of the Kona card not FCP. Open the Kona control panel app, go the the format tab and you will see the settings.
    Jared Picune
    Idea Spring Editing, Inc.
    Denver Final Cut Pro UG
    The Picune Blog | FCP Tips & Tricks
  • Tom Matthies
    October 23, 2006 at 7:09 pm
    The problem is that I am attempting to play out of Final Cut thru the Kona 3 board. When FCP is selected as active it will override the Kona control panel settings. Is there a way to play SD out from FCP and do the letterbox conversion in real time?
    Tom
  • Jeremy Garchow
    October 23, 2006 at 7:24 pm
    It will not override the Kona settings. Set up your Kona control panel with the SD to SD conversion, flip back to FCP and away you go.
    Jeremy
  • Tom Matthies
    October 23, 2006 at 7:32 pm
    Got it to work. Thank you. I had to go into the Kona control panel and select “secondary video” for SDI output#2. It works great. SDI output#1 is driving an Aja HDSDI to DVI converter which in turn drives a Dell 24″ client monitor. I was just monitoring the wrong output. Oops.
    Thanks again. This will save me a lot of time!
    Tom
