Activity Forums Adobe Premiere Pro Scrubbing leads to Stuttering in the Program Monitor (CS6)
  • Scrubbing leads to Stuttering in the Program Monitor (CS6)
    Posted by Steven Pribilinskiy on May 20, 2012 at 11:11 am
    When Scrubbing in Timeline the video is stuttering in the Program Monitor Pane and on the 2nd Monitor too.
    This problem was not exist in CS5.5 and older.
    I have figured out that this happens only when Reference Monitor is open and only when the “Gang to Program Monitor” is enabled.
    So I disabled this option and now everything fine, but the problem is that this option is not saved in Workspace/Project and furthermore it is automatically enabled when opening the Reference Monitor.
    Is there a way to fix this stuttering problem? Or at least force the “Gang” option to be Off?
    Steven Pribilinskiy replied 14 years, 4 months ago 2 Members · 3 Replies
  • Jon Barrie
    May 20, 2012 at 11:48 am
    Have you got the video panels in monitor 1?
    – JB
    Jon Barrie
    Adobe Video Solutions Consultant ANZ
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • Steven Pribilinskiy
    May 20, 2012 at 1:05 pm
    Stuttering persist regardless of Source/Program panels open state. also stuttering doesn’t depend on “Adobe Monitor 2” enabled state. I even tried to close all of the panels except Timeline, Program and Reference Monitor – same stuttering.
    So it depends only on the Reference Monitor.
    Also I have found out that this happens only when some scopes are viewed. Problem gone when setting Reference Monitor to Composite Video. So, it’s look like a solution – Set Reference Monitor to Composite Video and the main Program Panel View to some Scopes like RGB Parade – I have tried it and it works! But there’s again a a caveat – Program Panel View Mode is Not saved in Workspace/Project and Composite Video view is automatically selected after reopening the Program Monitor Pane 🙁
    Also the stuttering persist when the Mercury playback engine is set to Software only.
    Steven Pribilinskiy
    May 21, 2012 at 11:38 am
    Interesting whether you also have such an experience when using reference monitor on Windows version of Premiere 6?
    Steven Pribilinskiy
