scrubbing doesn’t work in external monitor (when in viewer)
when i scrub through a sequence, external video (via kona lhe card) displays (and scrubs) fine.
when i scrub through a clip in the viewer, it functions correctly in the cinema display, but the external video freezes on the initial frame and then jumps to whatever frame i’m at when i stop scrubbing. although, if i scrub veeeerrry slooowly it will work.
any advice or settings i can tweak to be able to scrub through the clips and view it on the external monitor? maybe the system isn’t quite powerful enough?
all the specs of the system/project are below.
thanks much.
tchandlerSystem:
fcp 6.0.4
qt 7.5.5
leopard 10.5.5Mac Pro 2 X 3ghz dual core
6 GB ramwith 23″ hd cinema display
20″ JVC DTV HD monitor
Kona LHEstorage: 4Bay MacGurus Burly w/ 4X 1TB Seagate Barracuda SATA drives (7200rpm)
connected via eSATA (Lycom 4 Port PCIe SATAII Host Card)footage: p2, 720/24pn (DVCPro 720p 59.94) loaded into FCP via Raylight
