Scrollbar “too fast” – accurate moving of the time slider while zoomed in
very often I need to zoom in the timeline to extreme levels, so that I can do frame-accurate cuts.
the problem is… once I am zoomed in this far it’s practically impossible to use the time slider. moving it just one pixle to the left or right throws my view off completely…
many programs have some kind of “sensitivity” option. for example moving the time slider while holding down shift makes it move a lot slower and holding ctrl-shift slows it down even more.
is there anything similar in premiere? or some other solution that allows accurate moving of the time slider while zoomed in
