Activity Forums Adobe After Effects Expressions ScriptUI Responsive with 4 buttons
  • ScriptUI Responsive with 4 buttons
    Posted by Vincenzo Imbimbo on January 28, 2023 at 3:22 pm
    Hello guys, i’m creating a ScriptUI with 4 buttons, and they are in a row orientation, what i want is to them change from “row” to “column” if the window gets resized, right now i have a piece of code that is working, but it changes all the buttons at once, i want them to change position one at a time.
    I mean, the button 4 will go down first, leaving buttons 1, 2 and 3 in the top and in a row, like this:
    123
    4
    If the window get smaller then the button 3 will go down having in the top 1 & 2 and the bottom 3 & 4, like this:
    12
    34
    And if it gets even smaller then it will be like this:
    1
    2
    3
    4
    Right now i have it from this:
    1234
    To this:
    1
    2
    3
    4
    This is my actual code:
    { function myScript(thisObj){
    function myScript_buildUI(thisObj){
    var myPanel = (thisObj instanceof Panel) ? thisObj : new Window("palette", "Power Loop", undefined, {resizeable: true, closeButton:true});
    var project = app.project;
    var comp = project.activeItem;
    res = "group{orientation:'row',\
    groupOne: Group{orientation:'row',\
    groupTwo: Group{orientation:'row',\
    groupThree: Group{orientation:'row',\
    groupFour: Group{orientation:'row',\
    myPanel.grp = myPanel.add(res);
    myPanel.onResizing = myPanel.onResize = function() {
    myPanel.grp.orientation = (myPanel.size.width > myPanel.size.height) ? 'row' : 'column';
    myPanel.layout.layout(true);
    var buttonSize = [30,30];
    var buttonOne = myPanel.grp.groupOne.add('button');
    var buttonTwo = myPanel.grp.groupTwo.add('button');
    var buttonThree = myPanel.grp.groupThree.add('button');
    var buttonFour = myPanel.grp.groupFour.add('button');
    buttonOne.text = "1";
    buttonTwo.text = "2";
    buttonThree.text = "3";
    buttonFour.text = "4";
    buttonOne.size = buttonSize;
    buttonTwo.size = buttonSize;
    buttonThree.size = buttonSize;
    buttonFour.size = buttonSize;
    return myPanel;
    var myScriptPal = myScript_buildUI(thisObj);
    if(myScriptPal != null && myScriptPal instanceof Window){
    myScriptPal.center();
    myScriptPal.show();
    myScript(this);
    Vincenzo Imbimbo replied 3 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
