Activity › Forums › Adobe After Effects Expressions › Scripting: how to access all the keyframes of a given property?
  • Scripting: how to access all the keyframes of a given property?
    Posted by Paulo Jan on November 9, 2014 at 12:03 am
    Hi all:
    I can check whether a given property is keyframed or not using the numKeys attribute, but is there a way to get a list of all the keyframes in that property?
    Thanks in advance.
    Dan Ebberts replied 11 years, 10 months ago 2 Members · 5 Replies
  • Dan Ebberts
    November 9, 2014 at 12:23 am
    What needs to be in the list?
    Dan
  • Paulo Jan
    November 9, 2014 at 2:15 pm
    The basics, time and value. (I realize now that this is a more complicated issue than I had first thought, since a keyframe can also have a lot of other attributes: hold or not, interpolation… but the ones I need in my case are just those).
  • Dan Ebberts
    November 9, 2014 at 3:54 pm
    I suspect what you want may be more complicated than this (file I/O maybe?) but something like this example would construct a string containing a list of key times and values:
    var myProp = app.project.activeItem.layer(1).property("Position");
    var str = "";
    for (var i = 1; i <= myProp.numKeys; i++){
    str += (i == 1 ? "" : "\r") + myProp.keyTime(i) + " " + myProp.keyValue(i).toString();
    alert(str);
    Dan
  • Paulo Jan
    November 9, 2014 at 7:49 pm
    Wow, thanks. Actually, I was just wondering how to access the keyframes at all; I didn’t realize that you could do that just by its index. Just a question: why do you start the for loop with 1 instead of 0? I’ve just had a quick glance at Adobe’s scripting guide and didn’t find any reference to that.
  • Dan Ebberts
    November 9, 2014 at 9:15 pm
    When using the property key methods, the key index numbers run from 1 through numKeys. You may be thinking of array indexing.
