Scripting Help
Posted by Videocool on August 3, 2005 at 9:56 pmHi there…
How do I assign a script to a keyboard Shortcut?
Thank You, SteveVideocool replied 21 years, 1 month ago 2 Members · 6 Replies -
Mike Kujbida
August 3, 2005 at 11:46 pmVegas 5 manual – p. 302
Vegas 6 manual – p. 341Options – Prefs – Keyboard.
Customize away 🙂 -
Videocool
August 4, 2005 at 12:01 amThanks Mike…
It’s actually page 357 in my pdf manual on Vegas 6.0.
And I follow along with most of the keyboard shortcut customizing prefs…
For instance I can set Control-Y to open the Tools/Scripting/RunScript
sequence.But what I would LIKE to do is Run a Specific Script from the shortcut… e.g. Control+Y would start the script for automatically cutting the clip to the Left of the Split.
I can rename the Script so it will appear at the top of the list.
I’ve also added a button to the toolbar to start the script. But I don’t know how to do a keyboard shortcut to that point either….
Sorry for the confusion…
Once I get the Keyboard shortcut figured out… I’ll add it to my ShuttlePro controller… which will just about cover my quick – cutting/editing needs.
Thanks again
Steve
Mike Kujbida
August 4, 2005 at 12:15 amHi Steve. I just looked in the index, it said p. 341, so that’s what I typed. Turns out p. 357 is for scripting.
Anyway, on to your problem. I just tried it and had no problem doing exactly what you want. In the Keyboard prefs, I click on the script I want to assign (in the Available Commands box – I already had my scripts loaded under Tools – Scripting) and then choose the shortcut I want by clicking in the “Press new shortcut keys:” box and entering the desired shortcut combination. Press “Assign” & “Apply”. Done.
Let me know if that works for you.Mike
Videocool
August 4, 2005 at 12:20 amHey Mike…
I got it worked out thanks again…
Like your setup I kept looking in Keyboard commands under tools/scripting/ (figured it would there)… but it was under Script.RemoveLeftEvent
Thanks again…
Steve…
Now Editing with one hand… all right – no comments from the peanut gallery…
Mike Kujbida
August 4, 2005 at 12:25 amSteve, glad you got it worked out.
It’s hard but I’ll restrain myself. I can’t promise the same from anyone else though 🙂
Mike
Videocool
August 4, 2005 at 12:44 amThanks Mike…
I’ve got another post on the way… It has a couple of links in it so it’s under review…
Just a big thank you to the guy who wrote the script…
Contour Design Shuttle Pro People…
You…
and the Creative Cow…
Steve
Sony VX-1000, P4, AMD, AMD64 laptop,
VegasVideo, ReelDVD, DVFILM, Lightwave, Photoshop, 18 years Independent Production
