Activity Forums Adobe After Effects Scripting: Change layer marker attributes
  • Scripting: Change layer marker attributes
    Posted by Peter Nepp on March 16, 2020 at 3:41 pm
    Hi there,
    I want to alter attributes of existing layer markers via ExtendedScript. But something like:
    app.project.item(50).layer(3).property("Marker").keyValue(1).comment = "New comment!";
    doesn’t work at all. I mean there’s no error message or something like this. But the actual value won’t change in the UI, and retrieving the value via script with:
    $.writeln(app.project.item(50).layer(3).property("Marker").keyValue(1).comment)
    after assigning a new one is returning the previous (unaltered) value instead. This is weird somehow. The documentation says these attributes on MarkerValue objects are “read” AND “write”. Did I get something wrong?
    Peter
    Peter Nepp replied 6 years, 6 months ago 2 Members · 4 Replies
  • Walter Soyka
    March 16, 2020 at 4:41 pm
    You have to use .setValueAtTime(), with the time of the marker you want to change and a MarkerValue object to change it to. Try something like this:
    app.project.item(50).layer(3).property("Marker").setValueAtTime(app.project.item(50).layer(3).property("Marker").keyTime(1), new MarkerValue("New comment!"));
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Peter Nepp
    March 16, 2020 at 5:07 pm
    Hi Walter,
    many thanks, that did the trick.
    This is still a bit weird to me. ????
    Peter
  • Walter Soyka
    March 16, 2020 at 7:38 pm
    It is a bit weird. The documentation doesn’t make this super-clear, but markers are basically a special kind of keyframe, and keyframe values are set with .setValueAtTime(). Not only that, but markers use a MarkerValue object as their data type, so if you want to change the comment text, you have to do so by creating a MarkerValue object to contain the comment.
    Walter Soyka
  • Peter Nepp
    March 17, 2020 at 12:06 pm
    Hi Walter,
    if this is the way to go, so be it. ☺
    My way to handle this conveniently:
    var ctrl = ....
    var marker = ctrl.property("Marker").keyValue(1);
    var markerTime = ctrl.property("Marker").keyTime(1);
    marker.label = 1;
    marker.comment = "New Comment!"
    ctrl.property("Marker").setValueAtTime(markerTime, marker);
    Thanks again,
    Peter
