Activity › Forums › Adobe Premiere Pro › Scripting bug when setInPoint and setOutPoint?
  • Scripting bug when setInPoint and setOutPoint?
    Posted by Ryan Gilmore on January 30, 2020 at 3:41 pm
    I’ve run into a frustrating brick wall when using:
    projectItem.setInPoint(seconds)
    projectItem.setOutPoint(seconds)
    …about 50% of the time the I/O points (in the source window) are set with a 1 frame error (sometimes 2 frames out). I feel like I’ve tried everything to discover what the pattern is, but it seems entirely random.
    I thought it might be something to do with drop frame, variable frame rates, the clip being different from the sequence, or other oddities, but the error occurs at simple constant frame rates like 25 fps. There just seems to be no rhyme or reason to the errors (although the same error occurs consistently on certain frames).
    There’s even a bigger problem with subclips, as the scripting environment thinks that all subclips start at frame 0.
    I’ve tried everything, including working in ticks, seconds or frames, and converting between them. Nothing made a difference.
    What I’m trying to accomplish is to set in/out on a set of clips, run a script to make smaller cuts from those source clips, and then restore the clips to the original I/O points. Got most of this working except I can’t restore all the clips to the original I/O points with this bug.
    Below is a test script I wrote. It gets the current I/O positions, stores them, and then sets them back to the same clip. Half the time the values are not the same!  Argh!  This makes it impossible set the clips I/O accurately.
    function framesToSeconds (frames, fps)
    return frames / fps;
    function secondsToFrames (sec, fps)
    return sec * fps;
    var projItems = app.project.rootItem.children;
    var clip = projItems[2];
    var fps = clip.getFootageInterpretation().frameRate;
    var setIn = clip.getInPoint().seconds;
    var setOut = clip.getOutPoint().seconds;
    var inFrame = secondsToFrames (setIn, fps);
    var outFrame = secondsToFrames (setOut, fps);
    var secIn = framesToSeconds (inFrame, fps);
    var secOut = framesToSeconds (outFrame, fps);
    clip.setInPoint( secIn );
    clip.setOutPoint( secOut );
    Ryan Gilmore replied 6 years, 7 months ago 1 Member · 1 Reply
  • Ryan Gilmore
    February 10, 2020 at 5:03 pm
    I’ve done some more testing. Although I don’t quite understand the source of the error, I believe I have figured out a fix for it.
    I tested 2 slugs, each 10 seconds long with different frame rates, and ran them through a loop and set the IO points of each frame. I checked each frame to see which frames came back wrong. What I found was:
    test_25fps_1280x720.mov : error on frames 211,209,207,205,203,201
    test_29fps_1024x576.mov : error on frames 251,244,242,122,121,61
    These errors weren’t random. Whenever I tried to set an in or out point on these frames it would ALWAYS round down 1 frame (I was wrong before about 50% of the frames being off, it’s actually less than 3%).
    My best guess is that there’s some precision error because there’s a calculation going somewhere involving large floating point numbers. I can’t confirm it, nor do I really understand how to fix that. But I did figure out I could test the in and out points after setting them, and if it didn’t match expectations I could reset the point by adding the duration of half a frame (in seconds). A full frame would just repeat the error, but half a frame would get Premiere to round up to the correct frame.
    This is the main part of my code:
    function fixAnyFrameErrors (clip, inFrame, outFrame, fps, halfFrame)
    var inSecSet = clip.getInPoint().seconds;
    var inFrameSet = secondsToFrames (inSecSet, fps);
    var outSecSet = clip.getOutPoint().seconds;
    var outFrameSet = secondsToFrames (outSecSet, fps);
    if ( parseFloat(inFrame) != parseFloat(inFrameSet) ) {
    clip.setInPoint( secIn + halfFrame );
    if ( parseFloat(outFrame) != parseFloat(outFrameSet) ) {
    clip.setOutPoint( secOut + halfFrame );
    var tps = 254016000000; // 2.54016e11 ticks per second (Premiere Pro constant)
    clip.addMetadata();
    var tpf = clip.videoInPoint.frame_rate;
    var frameDuration = tpf / tps; // in seconds
    var halfFrame = (frameDuration * 0.5);
    var inFrame = 201;
    var outFrame = 211;
    clip.setInPoint ( secIn );
    fixAnyFrameErrors (clip, inFrame, outFrame, fps, halfFrame);
