Activity Forums Adobe After Effects Expressions Scripting – Add to Essential Graphics Panel
  • Scripting – Add to Essential Graphics Panel
    Posted by Kevin Snyder on March 28, 2020 at 9:07 pm
    I’m trying to use this code to write a script so that I can add properties to the Essential Graphics Panel. Here’s the reference code.
    app.project.item(index).layer(index).propertySpec.addToMotionGraphicsTemplate(comp)
    I came up with this, but I’m totally new at this, so I might be completely off.
    app.beginUndoGroup("Add to EGP");
    function add(){
    var compName = app.project.activeItem.name;
    var myLayer = app.project.activeItem.selectedLayers[0];
    var propertySpec = myLayer.opacity;
    propertySpec.addToMotionGraphicsTemplate(compName);
    add()
    app.endUndoGroup();
    I received this error message when I run it.
    “Unable to execute script at line 7. After Effects error: Unable to call “addToMotionGraphicsTemplate” because of parameter 1. Comp 1 is not of the correct type.”
    Kevin Snyder replied 6 years, 4 months ago 2 Members · 4 Replies
  • Dan Ebberts
    March 28, 2020 at 10:03 pm
    I haven’t tried addToMotionGraphicsTemplate(), but my guess is that you need to provide it a comp object, not a comp name. Try that.
    Dan
  • Kevin Snyder
    March 30, 2020 at 7:54 pm
    Thanks, Dan. I appreciate it. After some trial and error, I finally have a working script. The current version will add the selected layer’s position to the Essential Graphics Panel. How do I make it run on all selected layers and not just the first one?
    function add(){
    var myComp = app.project.activeItem; //Active comp
    var selectProp = myComp.selectedLayers[0].position; //Position on selected layer;
    var myLayer = myComp.selectedLayers[0].name; //Get layer name;
    var myProp = "Position"; //Property name;
    var myControl = myProp + " " + "-" + " " + myLayer;//Combine property name and layer name
    selectProp.addToMotionGraphicsTemplateAs(myComp, myControl); //Add property to EGP and rename;
    app.project.activeItem.motionGraphicsTemplateName = "Master Properties"; //Set template name;
    myComp.openInEssentialGraphics(); //Opens comp in essential graphics panel;
    add()
    app.endUndoGroup();
  • Dan Ebberts
    March 30, 2020 at 8:50 pm
    I haven’t tested this, but something like this:
    function add(theLayer){
    var selectProp = theLayer.position; //Position on selected layer;
    var myLayer = theLayer.name; //Get layer name;
    var myLayers = app.project.activeItem.selectedLayers;
    for (var i = 0; i < myLayers.length; i++){
    add(myLayers[i]);
    app.endUndoGroup();
    Dan
  • Kevin Snyder
    April 1, 2020 at 3:42 am
    Dan, that works great. Thank you. I appreciate it. I’m trying to wrap my head around what you did to apply it to a version that works on any selected property. It will work with one property selected, but falls apart when I have more than one property selected.
    function addSelected(){
    var selectProps = myComp.selectedLayers[0].selectedProperties; //Selected properties in comp;
    var selectProp;
    var n;
    for (var i = 0; i < selectProps.length; i++){
    selectProp = selectProps[i];
    if (selectProp.propertyType == PropertyType.PROPERTY){
    switch(selectProp.propertyValueType){
    case PropertyValueType.OneD:
    n = 1;
    break;
    case PropertyValueType.TwoD:
    case PropertyValueType.TwoD_SPATIAL :
    n = 2;
    break;
    case PropertyValueType.ThreeD:
    case PropertyValueType.ThreeD_SPATIAL:
    n = 3;
    break;
    case PropertyValueType.COLOR:
    n = 4;
    break;
    default:
    n = 0; // just in case
    break;
    var myProp = myComp.selectedLayers[0].selectedProperties[0].name; //Get property name;
    var selectProp = app.project.activeItem.selectedProperties;
    for (var i = 0; i < selectProp.length; i++){
    addSelected(selectProp[i]);
