Activity Forums Adobe After Effects Expressions Script to replace fileGetDialog()?
  • Script to replace fileGetDialog()?
    Posted by Tim Stonesifer on April 22, 2010 at 3:47 pm
    I have a script which uses a line like:
    var nameFile = fileGetDialog("Select a text file to open.", "TEXT txt");
    However, the file I’m grabbing is always in the same location… I’ve used code like:
    var nameFile = "/v/file.txt"
    or var nameFile = "v:/file.txt"
    Nothing seems to work – I’m surely getting the syntax wrong. Can anyone point me in the right direction? Thanks.
    Tim Stonesifer replied 16 years, 4 months ago 2 Members · 2 Replies
  • Dan Ebberts
    April 22, 2010 at 4:55 pm
    Try this:
    var nameFilePath = “/v/file.txt”;
    var nameFile = File(nameFilePath);
    Dan
  • Tim Stonesifer
    April 22, 2010 at 4:58 pm
    Awesome, that’s it! Thanks Dan!
