Activity Forums Adobe After Effects Expressions script to copy multiple paths from one layer to multiple masks on another layer?
  • script to copy multiple paths from one layer to multiple masks on another layer?
    Posted by Constanti Dinu on December 3, 2021 at 1:52 pm
    hi,
    for starters, i have never wrote scripts in AE, only expression, so saying im new to this is an understatement.
    i have a shape layer with 300+ paths and i need to copy every path into an adjustment layer as a mask. i have done this manually by copying the path from the shape, add a new mask in the adjustment layer, and paste it there, but because i have to do this a lot of times, i kinda need a script. i tried my best with what’s below, so far ive managed to copy the path, add mask, paste the path as a mask, delete the first path. any ideas how to make this a loop?
    var myComp = app.project.activeItem;
    var mySourceLayer = myComp.layer(“de sters”);
    var myPath = mySourceLayer.property(“Contents”).property(1).property(“Path”);
    mySourceLayer.selected = true;
    myPath.selected = true;
    app.executeCommand(19); //Copy
    myPath.selected = false;
    mySourceLayer.selected = false;
    var myShape = myPath.value;
    var myDestLayer = myComp.layer(“1”);
    var myNewMask = myDestLayer.property(“Masks”).addProperty(“Mask”);
    var myNewPath = myNewMask.property(“Mask Path”);
    //myNewPath.setValue(myShape);
    myDestLayer.selected = true;
    myNewMask.selected = true;
    myNewPath.selected = true;
    app.executeCommand(20); //Paste
    myDestLayer.selected = false;
    app.executeCommand(18); //Copy
    Constanti Dinu replied 4 years, 9 months ago 2 Members · 2 Replies
  • Andrei Popa
    December 3, 2021 at 3:25 pm
    Hi Constanti.
    I am not 100% sure how the paths are organized inside your layer, but this or something close to this should work.
    var mySourceLayer = myComp.layer("de sters");
    var myDestLayer = myComp.layer("1");
    for (var i = 1; i <= mySourceLayer("Contents").numProperties; i++) {
    var myPath = mySourceLayer("Contents")(i)("Path") ;
    if(myPath !== null) copyPathToMask(mySourceLayer, myPath, myDestLayer);
    function copyPathToMask(mySourceLayer, myPath, myDestLayer) {
    app.executeCommand(18); //Cut
    var myNewMask = myDestLayer.property("Masks").addProperty("Mask");
    var myNewPath = myNewMask.property("Mask Path");
  • Constanti Dinu
    December 3, 2021 at 3:44 pm
    worked perfectly, mersi frumos Andrei
