Activity Forums Adobe After Effects Script to automate rendering of multiple identical compositions
  • Script to automate rendering of multiple identical compositions
    Posted by Graham Quince on June 18, 2009 at 12:08 pm
    Hi guys,
    Hoping there is an easy way to do this. I regularly have to digitise old video tapes and chop them up into 20 minutes segments and then render them out to sit on our intranet. Right now, I use Scenalyser to timer record the tapes, Premiere to edit the sequences then I import the project into AE, set the comp sizes to 640×480, shrink the PAL DV videos to fit and add them to the render queue.
    Is there any way to automate the manual composition size setting and video scaling (it’s always 87%) and render queue addition?
    Graham
    http://www.YouTube.com/ShiveringCactus – Free FX for amateur films
    Graham Quince replied 17 years, 3 months ago 3 Members · 3 Replies
  • Andy George
    June 18, 2009 at 4:12 pm
    Hi Graham,
    Not exactly what your looking for but maybe helpful.
    https://www.redefinery.com/ae/view.php?item=rd_RenderLayers
    This script renders each layer of a comp individually.
    So you could just create 1 composition, drop your video in,
    sequence layers and it should do the rest-
    -Andy
  • Jan Sherlink
    June 18, 2009 at 11:07 pm
    You can create an Output Module with Stretch or Crop settings,
    just keep your Pal Composition and let the Output Module scale down to 640×480
    cya,
    Jan
  • Graham Quince
    June 22, 2009 at 8:56 am
    Thanks for all the help guys.
    Jan, the trouble with using the compression stretch settings is the output includes the nasty black and white blocks recorded from the original picture. Resizing in AE we don’t scale down to see the overscan area.
    Dave, I’ve looked before for a batch program and ended up using AE. I wish PPro would just do batch.
    Andy, that’s a great site, very useful to have all the scripts together,
    thanks again everyone
    Graham
