Activity › Forums › Avid Media Composer › Script Sync Take Order
  • Script Sync Take Order
    Posted by Josh Stein on August 13, 2015 at 7:20 pm
    Script synced question:
    When I drag multiple takes from a bin (usually only happens on scns with over 8 or so takes), they line up on the script in what seems to be a random order…
    Any reason this would happen? The take column on the bin is correctly assigned to each take.
    Aren Hansen replied 8 years, 6 months ago 4 Members · 3 Replies
  • Michael Phillips
    August 14, 2015 at 12:01 am
    I’ll have to look into this. So up to 7 takes, order is correct and after that it gets mixed up? Is that consistent?
    Michael
  • Marian Jimenez
    June 7, 2017 at 4:30 pm
    Im more interested to find out why when I add a clip a second time I can’t get it to be in the right order, or move it to the right order.
    for example I used to put all the takes of a set up Take 1-5 on the script and if I found a reset I would just add take 2 again for example and it would sort next to the other take 2 clip and I didn’t have to delete take 3-5 in order to make the second clip of take 2 to be next to the first clip of take 2.
    Not sure if I’m explaining myself well.. let me know if you have any solution.
    Marian
  • Aren Hansen
    March 30, 2018 at 6:01 pm
    Hey,
    I’m struggling with this too. Did you find a solution/workaround?
