Activity › Forums › Adobe After Effects Expressions › Script Settings File
  • Andrei Popa
    January 22, 2022 at 7:42 am
    It is.
    Create your javascript object holding the settings. Then to save it to a file you need to serialize it. You can do that with .toSource(). This creates a string that you can later use with eval(). So save the string created by myVar.toSource() in a txt file and when you need that variable again, read the content of the file and pass it to eval(), like this:
    var mySettings = eval(contentOfFile);
  • Tomas Bumbulevičius
    January 24, 2022 at 6:19 pm
    Alternatively, have a .json settings file – not sure whether toSource is formattable option Andrei, is it? Like adding “tidy” tabulators and at least a bit of visual sense.
