Activity › Forums › Adobe After Effects Expressions › script selection
  • Dan Ebberts
    August 16, 2007 at 5:31 pm
    For a script to show up in the menu, you have to put it in the Support Files/Scripts folder. What is it that’s greyed out? I’m not sure what could cause that unless you don’t have the Pro version of 6.5.
    Dan
  • Marcosh
    August 16, 2007 at 6:56 pm
    Hey Dan,
    I do have the Pro version. It’s weird cause I have downloaded other scripts (not from that source though) and they worked fine.
    The only thing I noticed is that when I downloaded this last batch, the files came with a “.txt” after the “.jsx”. I deleted the “.txt” but the problem remained.
    Marcos H.
    Quad G5
    2GB RAM
    OS 10.4.7
    FCP 5.0.4
    AE 6.5
  • Filip Vandueren
    August 19, 2007 at 4:46 pm
    open the file in a text-editor and make sure it’s a script, and not-for example- a zipfile that got the .txt extension because of downlading.
    Make sure it actually has the extension .jsx by choosing Get Info (Command-I) in the finder.
