Activity Forums Adobe After Effects Expressions Script mysteriously crashing, can’t figure out why
  • Script mysteriously crashing, can’t figure out why
    Posted by Patrick Batterson on October 31, 2023 at 2:05 pm
    Hey guys,
    This script I’ve been working crashes and I’m running out of ideas as to why.
    It runs fine on my windows computer but on my mac, whenever I check the “Suffix” checkbox and click inside the Suffix text box After Effects crashes. All other checkboxes and text inputs work fine and behaves as expected. I’ve removed a lot of code to only present the problematic part, if any of you have any idea of why this is happening, I’d be super grateful.
    var panelGlobal = this;
    var scriptUIPanel = (panelGlobal instanceof Panel) ? panelGlobal : new Window("palette");
    if (!(panelGlobal instanceof Panel)) scriptUIPanel.text = "PerfectCompNamer";
    var prefixInput, clientInput, projectInput, placementInput, dimensionsWidth, dimensionsHeight, lengthInput, languageInput, suffixInput;
    var prefixCheckbox, clientCheckbox, projectCheckbox, placementCheckbox, dimensionsCheckbox, lengthCheckbox, languageCheckbox, suffixCheckbox;
    function enableDisableEdittext(checkbox, edittext) {
    edittext.enabled = checkbox.value;
    // SCRIPTUIPANEL
    scriptUIPanel.orientation = "column";
    scriptUIPanel.alignChildren = ["center","top"];
    scriptUIPanel.spacing = 10;
    scriptUIPanel.margins = 16;
    // NAMINGPROPERTIES
    var namingProperties = scriptUIPanel.add("panel", undefined, undefined, {name: "namingProperties"});
    namingProperties.text = "Naming Properties";
    namingProperties.orientation = "column";
    namingProperties.alignChildren = ["left","top"];
    namingProperties.spacing = 10;
    namingProperties.margins = 10;
    // CLIENTGROUP
    var clientGroup = namingProperties.add("group", undefined, {name: "clientGroup"});
    clientGroup.orientation = "row";
    clientGroup.alignChildren = ["left","center"];
    clientGroup.spacing = 10;
    clientGroup.margins = 0;
    var clientCheckbox = clientGroup.add("checkbox", undefined, undefined, {name: "clientCheckbox"});
    // CLIENTWRAPPER
    var clientWrapper = clientGroup.add("group", undefined, {name: "clientWrapper"});
    clientWrapper.preferredSize.width = 80;
    clientWrapper.orientation = "row";
    clientWrapper.alignChildren = ["left","center"];
    clientWrapper.spacing = 10;
    clientWrapper.margins = 0;
    var clientPropertyText = clientWrapper.add("statictext", undefined, undefined, {name: "clientPropertyText"});
    clientPropertyText.text = "Client:";
    // CLIENTGROUP
    var clientInput = clientGroup.add('edittext {properties: {name: "clientInput"}}');
    clientInput.preferredSize.width = 120;
    enableDisableEdittext(clientCheckbox, clientInput);
    // PROJECTGROUP
    var projectGroup = namingProperties.add("group", undefined, {name: "projectGroup"});
    projectGroup.orientation = "row";
    projectGroup.alignChildren = ["left","center"];
    projectGroup.spacing = 10;
    projectGroup.margins = 0;
    var projectCheckbox = projectGroup.add("checkbox", undefined, undefined, {name: "projectCheckbox"});
    // PROJECTWRAPPER
    var projectWrapper = projectGroup.add("group", undefined, {name: "projectWrapper"});
    projectWrapper.preferredSize.width = 80;
    projectWrapper.orientation = "row";
    projectWrapper.alignChildren = ["left","center"];
    projectWrapper.spacing = 10;
    projectWrapper.margins = 0;
    var projectPropertyText = projectWrapper.add("statictext", undefined, undefined, {name: "projectPropertyText"});
    projectPropertyText.text = "Project:";
    // PROJECTGROUP
    var projectInput = projectGroup.add('edittext {properties: {name: "projectInput"}}');
    projectInput.preferredSize.width = 120;
    enableDisableEdittext(projectCheckbox, projectInput);
    // PLACEMENTGROUP
    var placementGroup = namingProperties.add("group", undefined, {name: "placementGroup"});
    placementGroup.orientation = "row";
    placementGroup.alignChildren = ["left","center"];
    placementGroup.spacing = 10;
    placementGroup.margins = 0;
    var placementCheckbox = placementGroup.add("checkbox", undefined, undefined, {name: "placementCheckbox"});
    // PLACEMENTWRAPPER
    var placementWrapper = placementGroup.add("group", undefined, {name: "placementWrapper"});
    placementWrapper.preferredSize.width = 80;
    placementWrapper.orientation = "row";
    placementWrapper.alignChildren = ["left","center"];
    placementWrapper.spacing = 10;
    placementWrapper.margins = 0;
    var placementPropertyText = placementWrapper.add("statictext", undefined, undefined, {name: "placementPropertyText"});
    placementPropertyText.text = "Placement:";
    // PLACEMENTGROUP
    var placementInput = placementGroup.add('edittext {properties: {name: "placementInput"}}');
    placementInput.preferredSize.width = 120;
    enableDisableEdittext(placementCheckbox, placementInput);
    // DIMENSIONSGROUP
    var dimensionsGroup = namingProperties.add("group", undefined, {name: "dimensionsGroup"});
    dimensionsGroup.orientation = "row";
    dimensionsGroup.alignChildren = ["left","center"];
    dimensionsGroup.spacing = 10;
    dimensionsGroup.margins = 0;
    var dimensionsCheckbox = dimensionsGroup.add("checkbox", undefined, undefined, {name: "dimensionsCheckbox"});
    // dimensionsWRAPPER
    var dimensionsWrapper = dimensionsGroup.add("group", undefined, {name: "dimensionsWrapper"});
    dimensionsWrapper.preferredSize.width = 80;
    dimensionsWrapper.orientation = "row";
    dimensionsWrapper.alignChildren = ["left","center"];
    dimensionsWrapper.spacing = 10;
    dimensionsWrapper.margins = 0;
    var dimensionsPropertyText = dimensionsWrapper.add("statictext", undefined, undefined, {name: "dimensionsPropertyText"});
    dimensionsPropertyText.text = "Dimensions:";
    // dimensionsGROUP
    var dimensionsWidthInput = dimensionsGroup.add('edittext {properties: {name: "dimensionsWidthInput"}}');
    dimensionsWidthInput.preferredSize.width = 45;
    enableDisableEdittext(dimensionsCheckbox, dimensionsWidthInput);
    var dimensionsDivider = dimensionsGroup.add("statictext", undefined, undefined, {name: "dimensionsDivider"});
    dimensionsDivider.text = "x";
    var dimensionsHeightInput = dimensionsGroup.add('edittext {properties: {name: "dimensionsHeightInput"}}');
    dimensionsHeightInput.preferredSize.width = 45;
    enableDisableEdittext(dimensionsCheckbox, dimensionsHeightInput);
    // LENGTHGROUP
    var lengthGroup = namingProperties.add("group", undefined, {name: "lengthGroup"});
    lengthGroup.orientation = "row";
    lengthGroup.alignChildren = ["left","center"];
    lengthGroup.spacing = 10;
    lengthGroup.margins = 0;
    var lengthCheckbox = lengthGroup.add("checkbox", undefined, undefined, {name: "lengthCheckbox"});
    // LENGTHWRAPPER
    var lengthWrapper = lengthGroup.add("group", undefined, {name: "lengthWrapper"});
    lengthWrapper.preferredSize.width = 80;
    lengthWrapper.orientation = "row";
    lengthWrapper.alignChildren = ["left","center"];
    lengthWrapper.spacing = 10;
    lengthWrapper.margins = 0;
    var lengthPropertyText = lengthWrapper.add("statictext", undefined, undefined, {name: "lengthPropertyText"});
    lengthPropertyText.text = "Length:";
    // LENGTHGROUP
    var lengthInput = lengthGroup.add('edittext {properties: {name: "lengthInput"}}');
    //lengthInput.text = lastInputs.length;
    lengthInput.preferredSize.width = 120;
    enableDisableEdittext(lengthCheckbox, lengthInput);
    // LANGUAGEGROUP
    var languageGroup = namingProperties.add("group", undefined, {name: "languageGroup"});
    languageGroup.orientation = "row";
    languageGroup.alignChildren = ["left","center"];
    languageGroup.spacing = 10;
    languageGroup.margins = 0;
    var languageCheckbox = languageGroup.add("checkbox", undefined, undefined, {name: "languageCheckbox"});
    // LANGUAGEWRAPPER
    var languageWrapper = languageGroup.add("group", undefined, {name: "languageWrapper"});
    languageWrapper.preferredSize.width = 80;
    languageWrapper.orientation = "row";
    languageWrapper.alignChildren = ["left","center"];
    languageWrapper.spacing = 10;
    languageWrapper.margins = 0;
    var languagePropertyText = languageWrapper.add("statictext", undefined, undefined, {name: "languagePropertyText"});
    languagePropertyText.text = "Language:";
    // LANGUAGEGROUP
    var languageInput = languageGroup.add('edittext {properties: {name: "languageInput"}}');
    languageInput.preferredSize.width = 120;
    enableDisableEdittext(languageCheckbox, languageInput);
    // additionalProperties
    var additionalProperties = scriptUIPanel.add("panel", undefined, undefined, {name: "additionalProperties"});
    additionalProperties.text = "Additional Properties";
    additionalProperties.orientation = "column";
    additionalProperties.alignChildren = ["left","top"];
    additionalProperties.spacing = 10;
    additionalProperties.margins = 10;
    // prefixGROUP
    var prefixGroup = additionalProperties.add("group", undefined, {name: "prefixGroup"});
    prefixGroup.orientation = "row";
    prefixGroup.alignChildren = ["left","center"];
    prefixGroup.spacing = 10;
    prefixGroup.margins = 0;
    var prefixCheckbox = prefixGroup.add("checkbox", undefined, undefined, {name: "prefixCheckbox"});
    // prefixWrapper
    var prefixWrapper = prefixGroup.add("group", undefined, {name: "prefixWrapper"});
    prefixWrapper.preferredSize.width = 80;
    prefixWrapper.orientation = "row";
    prefixWrapper.alignChildren = ["left","center"];
    prefixWrapper.spacing = 10;
    prefixWrapper.margins = 0;
    var prefixPropertyText = prefixWrapper.add("statictext", undefined, undefined, {name: "prefixWrapper"});
    prefixPropertyText.text = "Prefix:";
    // prefixGROUP
    var prefixInput = prefixGroup.add('edittext {properties: {name: "prefixInput"}}');
    prefixInput.preferredSize.width = 120;
    enableDisableEdittext(prefixCheckbox, prefixInput);
    // suffixGROUP
    var suffixGroup = additionalProperties.add("group", undefined, {name: "suffixGroup"});
    suffixGroup.orientation = "row";
    suffixGroup.alignChildren = ["left","center"];
    suffixGroup.spacing = 10;
    suffixGroup.margins = 0;
    var suffixCheckbox = suffixGroup.add("checkbox", undefined, undefined, {name: "suffixCheckbox"});
    // suffixWRAPPER
    var suffixWrapper = suffixGroup.add("group", undefined, {name: "suffixWrapper"});
    suffixWrapper.preferredSize.width = 80;
    suffixWrapper.orientation = "row";
    suffixWrapper.alignChildren = ["left","center"];
    suffixWrapper.spacing = 10;
    suffixWrapper.margins = 0;
    var suffixPropertyText = suffixWrapper.add("statictext", undefined, undefined, {name: "suffixPropertyText"});
    suffixPropertyText.text = "Suffix:";
    // suffixGROUP
    var suffixInput = suffixGroup.add("edittext", undefined, undefined, {name: "suffixinput"});
    suffixInput.preferredSize.width = 120;
    enableDisableEdittext(suffixCheckbox, suffixInput);
    // PREVIEWPANEL
    var previewPanel = scriptUIPanel.add("panel", undefined, undefined, {name: "previewPanel"});
    previewPanel.text = "Name Preview";
    previewPanel.preferredSize.width = 260;
    previewPanel.orientation = "column";
    previewPanel.alignChildren = ["left","top"];
    previewPanel.spacing = 10;
    previewPanel.margins = 10;
    var previewText = previewPanel.add("statictext", undefined, undefined, {name: "previewText"});
    previewText.text = "StaticText";
    previewText.preferredSize.width = 120;
    previewText.alignment = ["center","top"];
    // buttonWrapper
    var buttonWrapper = scriptUIPanel.add("group", undefined, {name: "buttonWrapper"});
    buttonWrapper.orientation = "row";
    buttonWrapper.alignChildren = ["left","center"];
    buttonWrapper.spacing = 10;
    buttonWrapper.margins = 0;
    var applyButton = buttonWrapper.add("button", undefined, undefined, {name: "applyButton"});
    applyButton.text = "Apply Naming";
    var cancelButton = buttonWrapper.add("button", undefined, undefined, {name: "cancelButton"});
    cancelButton.text = "Cancel";
    prefixCheckbox.onClick = function() {
    updatePreviewText();
    clientCheckbox.onClick = function() {
    projectCheckbox.onClick = function() {
    placementCheckbox.onClick = function() {
    dimensionsCheckbox.onClick = function() {
    lengthCheckbox.onClick = function() {
    languageCheckbox.onClick = function() {
    suffixCheckbox.onClick = function() {
    scriptUIPanel.show();
    Patrick Batterson replied 2 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
