Activity Forums VEGAS Pro Script for sync (time date)
  • Script for sync (time date)
    Posted by Leaning Less on April 17, 2014 at 3:22 pm
    Hi! Is there a script for synchronisation mov-files according to the time date with high precision (up to the fractions of seconds)?
    I’m have used that script but it doesn’t satisfy me, or i don’t use it correctly.
    7379_synchr.cs.zip
    Leaning Less replied 12 years, 4 months ago 2 Members · 9 Replies
  • 9 Replies
  • Grzegorz Kwiatkowski
    April 18, 2014 at 2:02 pm
    Try Vegasaur. It has the option to sync media using date modified file attribute.
  • Leaning Less
    April 18, 2014 at 3:35 pm
    I have Vegasaur 1.9.4 Try version, but can’t find this function. Please tell me.
    April 18, 2014 at 3:40 pm
    it is not so obvious. I am not in front of my computer right now but I think you will find it somewhere in Quick Properties. Sort files using date modified.
  • Leaning Less
    April 18, 2014 at 3:47 pm
    Looked again, but found only sort events chronologically.
    April 18, 2014 at 4:08 pm
    It should be under PLACEMENT tab. Sync using date modified.
  • Leaning Less
    April 18, 2014 at 4:24 pm
    It’s strange, but I don’t have placement tab
  • Leaning Less
    April 19, 2014 at 4:25 am
    I think I found it in the quick propeties.
    April 19, 2014 at 7:15 am
    Exactly. Does it work for u?
  • Leaning Less
    April 19, 2014 at 2:51 pm
    It works. but date modified from canon dslr aren`t correct. For example, if date modified of the first file is 00:00, then in its minute duration the date modified of the next file can be shown as 00.50. Have you encountered this problem?
    Recorded time/date is missing 🙁
