Activity Forums Adobe After Effects Expressions Script Button with Modifier Key
  • Script Button with Modifier Key
    Posted by Kevin Snyder on April 29, 2022 at 3:58 pm
    Is it possible to use a modifier key on a script button? I would like a regular click of a button to run a function and a SHIFT + Click to run a different function. Example:
    button1.onClick = addAnchor
    button1.onClick + SHIFT = addAll
    Kevin Snyder replied 4 years, 3 months ago 2 Members · 2 Replies
  • Dan Ebberts
    April 29, 2022 at 4:19 pm
    I don’t think you can do exactly what you’re asking for, but you can check for modifier keys inside your onClick function. To check for the shift key key, you would do something like this:
    var myState = ScriptUI.environment.keyboardState;
    if (myState.shiftKey){
    // do shift + click function
    }else{
    // do regular click function
    It’s in the JavaScript Tools Guide.
  • Kevin Snyder
    April 29, 2022 at 4:51 pm
    Thank you for making me look at it in a different way. Got it working.
