Scrip for lengthening event in two times
Posted by Leaning Less on June 8, 2015 at 9:53 pmIt may loop event. Is there a such script?
David Eon replied 11 years, 2 months ago 4 Members · 4 Replies -
Bob Peterson
June 9, 2015 at 2:03 amDo you mean that you want to double the time that an event is seen, and that a loop would be acceptable? If that is what you mean, a script is unnecessary. Simply drag the right border of an event, and pull it right to cover the desired time period. The item will repeat just as if it was looping.
Leaning Less
June 9, 2015 at 7:42 amI deal with great amount of events and that’s why I need special hotkey for such action.
Edward Troxel
June 14, 2015 at 7:38 pm -
David Eon
June 16, 2015 at 4:22 amVegasaur’s Quick Properties has an event tab that you can set playback rate to .5 and check the “adjust length”. You can apply it to all your events at once! Let me know if that helps. Thanks!
DavidEon
