Activity Forums Apple Final Cut Pro Legacy screwed by iTunes upgrade
  • screwed by iTunes upgrade
    Posted by Mark Barroso on November 13, 2008 at 3:37 pm
    I’m using FCP 4.5, which, as many of you who are holding on to old software because you can’t afford the new stuff know, only works with QT 7.2 and below. I inadvertently allowed iTunes to upgrade to 8.0 (damn those upgrades!)and now it will not work with QT 7.2. If I upgrade my QT, I cannot use FCP 4.5.
    Of course this is Apple’s way of forcing you to always buy, buy, buy. I’ve tried re-installing iTunes 7.5 from my backup drive, but it doesn’t work because it says the Library was created with a newer version.
    Workaround, anyone? Or a way to revert iTunes back without reverting all of the computer files?
    FCP 4.5 /
    OS 10.4.9 /
    1Ghz G4 powerbook + 1 G ram /
    Daisy chained: LaCie FW 400 150 GB and G-tech 500 HD
    G-Tech Quad 750GB connected by eSATA PCMCIA card
    playback deck: Pan dv2500
    Mark Barroso replied 17 years, 10 months ago 2 Members · 2 Replies
  • Shane Ross
    November 14, 2008 at 12:08 am
    Delete the iTunes Library. You will have to import the music again, and make your playlists, but at least you can get it working.
    Shane
  • Mark Barroso
    November 14, 2008 at 1:41 pm
    Thanks, Shane. BTW – I thought your DVD on getting organized in FCP was great.
    FCP 4.5 /
    OS 10.4.9 /
