Activity › Forums › Adobe After Effects › Screen Saver
Screen Saver
Posted by Philip Lackmaker on May 19, 2009 at 5:20 pmHey I got to make a screen saver and I am unsure of the right pixel settings that I need to use. Any help would be great?
Michael Mulet replied 10 years ago 4 Members · 5 Replies -
Richard Harrington
May 20, 2009 at 3:18 amAE doesn’t make screen savers
Richard M. Harrington, PMP
Author: Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and ATS:iWork
Philip Lackmaker
May 20, 2009 at 9:54 amCan I not make the animation in AE as a quick time then put it in to flash. if i can’t make a screen saver in AE how would I make the screen saver?
Paul Hennell
May 21, 2009 at 11:22 amYeah, by exporting as flash/to flash there are ways to turn that into a screen saver – check you know what you’re doing before you start though – most screensavers are more programed/coded rather then animated and while a looping video can be made into a screensaver it might be harder than you’re thinking.
As for video size, depends a bit on the monitor size I’d guess. Not sure what the standard monitor is these days – check what whoever you’re making it for uses and look at the options in the program you’ll actually make it into a screensaver with are. (I.e. You might not be able to scale up only down, you might have to add borders on widescreen etc.)
Good luck.
Only in after effects do children get to pick and whip their parents.
https://hennell-online.co.uk -
Philip Lackmaker
May 21, 2009 at 11:30 amHey
Thanks for that I just spoke to my studio manger and basically someone else is doing all the tecnical parts of it. Thanks for the help -
Michael Mulet
August 30, 2016 at 6:08 pmHere is a plugin that lets you export a screen saver straight from After Effects/Premiere: https://aescripts.com/screen-saver-exporter/
