Activity › Forums › Apple Final Cut Pro Legacy › screen rewinding efx
Posted by James Lee on February 24, 2006 at 6:38 pmHow do i create the efx where the shot looks like someone pushed the rewind button on a VHS tape? Not quite sure how else to describe this…this efx is used alot on TV show on MTV or VH1.
thanks!
JLes Kaye replied 20 years, 7 months ago 5 Members · 5 Replies -
David Roth weiss
February 24, 2006 at 7:49 pmThat can easliy be achieved with keyframing uisng the Time Remap feature in the Motion tab, but of course you’ll have to learn how the keyframer works if you don’t know that already.
Matthew Brunn
February 24, 2006 at 7:55 pmI just run tape backward and digitize noncontrolable, I get the distortion and everything.
Hope this helps-
Matthew
Quad 2.5 G5
OSX 10.4.X
Ram 4GB
FCP 4.5/AE 6.5/DVDSP3 -
Doug Bassett
February 24, 2006 at 7:59 pmhttps://dougbassett.com/rewind.mov
I used Tinderbox bad TV in this spot but you could lay your material out to tape and then do a capture now while manually rewinding the tape. -
James Lee
February 25, 2006 at 3:05 amduh….rewind the tape backward and capture………………………
I was so use to plugins..i though for sure someone had it. 🙂
thanks all!
Les Kaye
February 28, 2006 at 4:56 pmYou could try the Replicate filter and play with size and position settings.
