Activity Forums Adobe After Effects Screen Replacement help for Galaxy S8 with round corners.
  • Screen Replacement help for Galaxy S8 with round corners.
    Posted by Ben Ellis on July 17, 2019 at 8:55 pm
    I need to do a screen replacement in After FX using Mocha. The phone is a Samsung Galaxy S8 and the footage in Premiere is 4K DCI scaled down to 2K DCI. I might just render out a plate at 2K DCI to track in Mocha, but does anyone know the correct screen dimensions for a Galaxy S8?
    Also, Mocha will let me corner pin, but the phone has rounded corners. How do I deal with that?
    I’m not super great in AFX as I’m mostly an Editor, but I’ve managed to hobble by with iPhone screen replacements before. I’ve never replaced a Galaxy S8 before, let alone a screen with rounded corners.
    Any help would be super appreciated!
    Ben
    Ben Ellis
    Producer. Director. Editor
    https://www.benellis.com
    Ben Ellis replied 7 years, 2 months ago 4 Members · 5 Replies
  • Michael Szalapski
    July 19, 2019 at 6:53 pm
    Use the normal screen replacement workflow, but do it with a precomp in which you’ve rounded the corners of the footage.
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
  • Ben Ellis
    July 19, 2019 at 8:12 pm
    Thanks for the reply!
    I’m not really sure how to round the corners of the footage. I’m kinda a newbie with After Effects.
    I think I’m going to have to create the new UI myself. I don’t know the screen dimensions of a Galaxy S8. Also, do I have to keep this in mind when composing for 2K DCI?
    Ben
    Ben Ellis
  • Tomas Bumbulevičius
    July 19, 2019 at 8:22 pm
    Do you need to not only make the roundness, but also distort the view a bit in the corners?
    If not above, just add shape layer in the pre-comp, add roundness modifier to it and adjust the value to match the mockup device.
    Find out more:
    After Effects Tutorials: motion design, expressions, scripting.
    Boxer – Dynamic Text Boxes Template with a Live Preview
  • Ross Shain
    July 22, 2019 at 9:24 pm
    I would recommend using Mocha to mask out the screen with rounded corner mask.
    When you track in Mocha AE or Mocha Pro, you can also link that track data to a mask layer.
    You can comp your flat, square screen on top of the tablet, pre-comp, then use your Mocha generated mask with round corners… in AE, you select “Convert to AE Mask”.
    Ross Shain
    Boris FX / Imagineer Systems
    https://borisfx.com/products/mocha/
  • Ben Ellis
    July 22, 2019 at 10:18 pm
    Thanks Ross!
    I have a lot more to learn about Mocha. I’ve only used it so far for tracking phones with rectangular screens and then pasting corner pin data in After Effects. It sounds like you basically get rounded corners is by placing a “rounded” mask as an additional layer in After Effects… if I’m following correctly.
    Ben
    Ben Ellis
