Screen Preview in Blackmagic Media Express Flickers
Hello, I have a problem with my Black Magic Intensity Pro Capture Card. First off, here are some of my basic system specs:
Windows 7 x86
4 GB RAM
Intel Core 2 Quad CPU Q6600 @2.40 GHzOk so I bought this capture card new and unused, and I have been able to install and use it completely perfectly with my Xbox 360 (I use 720p resolution). I used it to stream live gameplay to justin.tv Then Just yesterday I got the “blue screen of death” with the error: Process_Has_Locked_Pages. After rebooting my computer, I found that my card no longer worked; in the BMI control panel everything was greyed out, and when opening BM Media Express, it said “black magic drivers or blackmagic hardware could not be found”. What I did next was to uninstall and reinstall the drivers as well as media express. The same problems still remained. I then proceeded to uninstall the drivers and media express again, but then I transferred my card from a PCIe x16 slot to a PCIe x1 slot. Then I reinstalled everything again, and it worked! sort of…
I put all my settings back to normal as much as I could remember, but the problem that I have now is that when I open either BM Media Express, or Adobe Flash Media Live Encoder, the preview of the xbox input flickers on and off from the actual xbox screen, to a totally black screen. Here is what is happening: https://www.youtube.com/watch?v=KDtLxiWjFxYAlso here are my settings for the BM Control Panel, BM Media Express, and Adobe FMLE:
https://i50.tinypic.com/345l9px.jpg
https://i48.tinypic.com/210yr9g.jpg
https://i50.tinypic.com/j624he.jpgThe weirdest part about all this, is that my connection is as follows: Xbox 360 — BMIP — Monitor
The above connections are all done with HDMI cables. On to the weird part, my monitor shows my xbox screen 100% perfectly, no flickering whatsoever. This must mean that my card is working, because if something was wrong with it, there is no way that the output would be working.
If anyone has any suggestions on any settings I should change, or any help at all, please let me know. Thank you.
