Activity Forums Adobe After Effects Screen Capture with recorded mouse position wanting to be used to influence camera movement
  • Screen Capture with recorded mouse position wanting to be used to influence camera movement
    Posted by Thomas Brigantino on February 22, 2016 at 9:12 am
    I am using MiniMouseMacro to capture the x,y position of my mouse cursor relative to the resolution of my screen, 2560×1600.
    In conjunction with that, I am capturing my screen using Open Broadcast Software which allows me to record demonstrations I share with photographers in Photoshop.
    That recording, the footage of the screen capture, is then brought into After Effects, put into a composition and the layers 3D switch is turned on.
    My intent is to provide a little richer visual experience than just flat footage playing through.
    The idea is to take that mouse data, where I have the x,y coordinates recorded every 25ms, bring that into After Effects and have it be repurposed as a gentle influencer of movement to where the cameras is pointing, not to follow exactly and to feel like it is being tugged in the direction of the area where I am working in Photoshop.
    The x,y coordinates can be broken out into an spreadsheet and further saved as a delimited text file.
    Any suggestions or solutions would be thoroughly appreciated.
    Thank you kindly,
    Thomas
    Thomas Brigantino replied 10 years, 7 months ago 2 Members · 2 Replies
  • Kalleheikki Kannisto
    February 22, 2016 at 12:10 pm
    If you copy some position keyframes and paste them into a plain text document, you’ll see how they are formatted for AE. It’s a very simple and straightforward format.
    You can format the keyframe information in a spreadsheet application, copy it to a plain text document, add the additional lines that AE expects into the document and copy and paste the lot to a null’s position. From there you can generate camera movement, add a smooth expression, etc.
    25 ms per frame means 40 fps, so you’d want to make your comp fps that.
    I’ve turned accelerometer input into 3D motion this way.
  • Thomas Brigantino
    February 22, 2016 at 12:44 pm
    Kalle,
    Good morning, thank you so very much for taking the time out to share that response and the conversion to fps.
    It seems you have approached the matter, although, in-terms of applying it to the front facing of a camera…is it best to attach the camera to a null object or directly apply the coordinate information to the camera?
    Thank you again for sharing that information.
    Kindly,
    Thomas
