Activity › Forums › Adobe After Effects › Screen capture video in after effects. Resolution question
  • Screen capture video in after effects. Resolution question
    Posted by Cecilia Ruiz-smith on August 10, 2011 at 3:02 pm
    Hi, I’m working on an AE project that includes footage captured directly from my monitor. I used Capture Wiz to capture Google Earth tours. I captured the video at 1280 x 720 using these settings from CaptureWiz: Export as WMV, 32bit,29.97fps. I then imported the footage into AE composition and interpreted the footage to fit the composition: 720×480 standard NTSC widescreen 29.90/fps.
    Rationale: Initially, I tried capturing google earth tour using their settings for standard ntsc (720×486)to match the composition settings for my AE project (ntsc standard widescreen) but this rendered a worse image this is why I decided to try a higher resolution capture (1280×720) hoping that it would look better in After effects after rendering. It helped but not that much
    When I render the AE footage as avi (best settings, lossless) then convert to MPEG2-DVD (using ntsc progessive high quality widescreen setting in the adobe media encoder) the resolution looks somewhat soft. Is there anything I can do to boost imported film footage resolution?
    Any advice would be appreciated
    THANK YOU!
    Cecilia Ruiz-smith replied 15 years, 1 month ago 39,424 Members · 1 Reply
  • Cecilia Ruiz-smith
    August 11, 2011 at 5:24 pm
    Thanks for taking the time to answer my question. Since then, I’ve been running tests and I found that outputting from media encoder using “match source attributes at highest quality” makes the image a bit sharper. I can live with this little improvement.
    Also, I was gratified to learn from you that I’ve done all of the right things to try and get the best image possible for DVD. I can live with the results.
