Activity › Forums › Apple Final Cut Pro Legacy › Scopes in FCP
Scopes in FCP
Posted by Pikeymick on December 30, 2005 at 9:52 pmDoes anyone know about using the HD scopes built into FCP? Are their any glitches to using the Video Scopes in the Log and Capture to check video? Etc…
FWalter Biscardi replied 20 years, 9 months ago 3 Members · 2 Replies -
Shane Ross
December 30, 2005 at 11:15 pmThe scopes are a mess. They sample random areas, and leave out the information OUTSIDE the Picture Safe entirely…
https://www.larryjordan.biz/articles/lj_scopes_warn.html
And if you are capturing via firewire, you can’t manipulate the brightness, contrast or anything…it comes in as a straight file.
If you are doing any serious broadcst work, I’d recomment getting an external set of scopes.
https://www.larryjordan.biz/articles/lj_scopes.html
Shane Ross
Alokut Productions
http://www.lfhd.net -
Walter Biscardi
December 30, 2005 at 11:37 pm[Shane Ross] “And if you are capturing via firewire, you can’t manipulate the brightness, contrast or anything…it comes in as a straight file.”
That’s the same as capturing SDI, you can’t adjust anything on the way in either as it’s a Digital file just like Firewire. If you have a TBC on your deck, then you’re good to go.
As for the scopes, they’re actually quite good except for the fact that they don’t sample anything outside the Safe Title area. I’ve been using them for some HD broadcast work here and nothing has been rejected yet for video levels.
However, I did just add Final Touch HD for both real-time color correction and fully accurate HD scopes. The cheapest good HD Scope I could find was about $11k. Final Touch HD is about $4k. So I went with that to get both the CC tool and an accurate scope.
Walter Biscardi, Jr.
https://www.biscardicreative.comDirector, “The Rough Cut”
https://www.theroughcutmovie.comNow editing “Good Eats” in HD for the Food Network
