Activity › Forums › Adobe After Effects › Sclae multiple layers to a fixed percent
  • Sclae multiple layers to a fixed percent
    Posted by Marbelle on October 25, 2006 at 10:55 am
    Hi guys,
    Hopefully someone can figure out how to solve this problem – it’s probably really simple but I can’t figure out how to do it.
    I have a completed project which was wrongly created as a Square Pixel comp instead of a PAL HDV comp, so when I drop in my footage everything is out of wack. I’ve change the comp settings to the correct ones but need to scale several layers from w 100% h 100% to w 75% h 100%. Some of the layers which will need to be resized in a similar way are scaled in the animation to a variety of sizes e.g. 69% 328% etc.
    My question is, knowing that the unscaled footage needs to have it’s width reduced by 25%, is there a quick way that I can select all instances of that footage, with their varying scales and globally reduce their width scale by 25% relevant to their current scale?
    I hope that makes sense.
    Thanks for the help
    MarBelle
    It’s better to have a gun and not need one, than to need a gun and not have one!
    Andrew Kramer replied 19 years, 11 months ago 2 Members · 4 Replies
  • Andrew Kramer
    October 25, 2006 at 12:28 pm
    Perhaps a null object might help. What you want to do is parent all the layers you want to uniformlly resize and link them to the null. Then resize the null and the other layers will adjust relative to there current size and position.
    Good Luck,
    Andrew Kramer
    https://www.videocopilot.net
  • Marbelle
    October 25, 2006 at 1:06 pm
    Ah excellent, cheers for that Andrew.
    I just tried that out and it seems to be working perfectly, you saved me a long tedious resizing job with a calculator at my side 🙂
    MarBelle
  • Marbelle
    October 25, 2006 at 2:54 pm
    Even speedier, I like it.
    Cheers!
  • Andrew Kramer
    October 25, 2006 at 4:08 pm
    Alright Dave, IT ON! ; )
