Activity › Forums › DaVinci Resolve › scene cut detection, conforming, a simple cut …..
  • scene cut detection, conforming, a simple cut …..
    Posted by Julien Alary on August 22, 2011 at 4:07 pm
    Just want to say to blackmagic that your scene detector is very bad. Lustre had a better scene detector in 2005, Nucoda’s is hundred times better.
    And please, let us be able to split/cut in any timeline, not just the master timeline. This is lame.¨
    Thank you
    Dan Moran replied 15 years, 1 month ago 2 Members · 1 Reply
  • Dan Moran
    August 22, 2011 at 8:49 pm
    Hey Julien,
    Are you using v8 of Resolve?
    If so it’s easy to add cuts to your timelines.
    On the conform page you can easily add cuts, move edit points, if you overlap clips it will add a transition for you and more Etc…
    I haven’t found any issues using the scene detector or toolset but if you have any feedback please do send it to davincihelp@Blackmagic-design.com and I’ll check it out for you.
    D
    Dan Moran
    DaVinci Application Specialist
    Blackmagic Design EMEA
