Activity Forums DVD Authoring Scenarist rejecting restroed assets
  • Scenarist rejecting restroed assets
    Posted by Benn Gunn on February 5, 2008 at 12:49 pm
    I just restored an old Creator project using Retrospect. I need to use the video and audio assets to build anew bversion of the project. However, the video assets will not import in Scenarist. They are Creator encodes so I have had to join the mpeg segements in MS DOS to create a stream which Scenarist should recognise. I have always done this in the past when using Creator encodes and never had problems. This time I get the following error message (Error This video has unknown picture type. File offset = 335556041. [C:\BHprog1.mpv]) and Scenarist rejects the asset.
    Is this just a corrupt restore or is there anything else I can do? I have run it through Procoder to create a new mpeg and this imports without issue, and the origianl file can be played in software players such as Cineplayer and Nero.
    Benn Gunn replied 18 years, 7 months ago 2 Members · 2 Replies
  • Max Kovalsky
    February 5, 2008 at 1:15 pm
    It must not like the header. Try running your mpeg though ReStream. You can also try joining the mpegs within Scenarist by using the “multi-data asset” function.
    Max
    Author
    New York
    Area4.tv
  • Benn Gunn
    February 5, 2008 at 2:00 pm
    Already tried all that in the meantime! Neither worked out for me.
