Activity Forums VEGAS Pro ScatterShot question
  • ScatterShot question
    Posted by Bob Moyer on June 25, 2014 at 8:06 pm
    I just downloaded version 1.0.8. In the lower right section of the extension screen where you can animate the rotation, I do not have ANY boxes showing the degree of rotation on any of the scatter type tabs. I have the up/down arrows to control the rotation amount but no boxes showing what the amount is. I uninstalled it and reinstalled it but I have the same problem. What have I done wrong?
    Bob
    Win7/64 – Vegas Pro 13
    Bob Moyer replied 12 years, 2 months ago 2 Members · 4 Replies
  • John Rofrano
    June 26, 2014 at 11:55 am
    [Bob Moyer] “I just downloaded version 1.0.8. In the lower right section of the extension screen where you can animate the rotation, I do not have ANY boxes showing the degree of rotation on any of the scatter type tabs.”
    Could it be a font size problem? Do you have your Windows font DPI set to something other than 100%. This messes up a lot of Windows programs because Windows does not manage fonts properly once you change the default size.
    If that’s not your problem, can you post a screen shot or send an email to ultimatesupport here at VASST and we’ll get you working again.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Bob Moyer
    June 26, 2014 at 4:50 pm
    “Could it be a font size problem? Do you have your Windows font DPI set to something other than 100%. This messes up a lot of Windows programs because Windows does not manage fonts properly once you change the default size.”
    John,
    As usual, you are correct. I have had this laptop for 4 years and never had an occasion to check the font size. It was set for “125% -Default”. Once I changed it to 100% the small windows were visible in ScatterShot. However, now my font is sooooo small. Are there any other options to have the default font size and the windows visible in Scattershot at the same time? I will attempt to attach a .jpeg of what I was seeing. Thanks again for your prompt reply and I apologize for my error.
    Bob
  • John Rofrano
    June 26, 2014 at 5:49 pm
    [Bob Moyer] “Once I changed it to 100% the small windows were visible in ScatterShot. However, now my font is sooooo small. “
    Yea, that’s what it sounded like. So you paid for a high resolution display and then you are stretching your fonts to make the resolution lower. Hmmm…
    [Bob Moyer] “Are there any other options to have the default font size and the windows visible in Scattershot at the same time?”
    Unfortunately no. I would have to look into making the window layout larger but then it’s going to look strange when the fonts are the regular size. Since most people use the normal font size that’s what I designed it for.
    ~jr
  • Bob Moyer
    June 26, 2014 at 6:14 pm
    Thanks, John. I will learn to live with it, no big problem, I just thought I would ask.
    Bob
