Activity Forums Avid Media Composer scanning for unrendered audiosuite plugins
  • scanning for unrendered audiosuite plugins
    Posted by Cesar Barrantes on July 10, 2009 at 6:16 am
    I am having an extremely difficult time exporting a QT movie, from a 6 minute sequence. I’ve tried exporting as h.264 or mpeg 4 but get a scanning for unrendered audiosuite plugins message and nothing happens. I don’t even have any audio suite effects in the timeline. Exporting same as source works fine but the file size ended up being close to 8 gb. I tried having the audiosuite tool open before I do an (in/out) expert render and then exporting. That didn’t work. I also made a dupe of the sequence and created an audio mixdown. No luck either. Can someone please help?
    Hugue Loiselle replied 16 years, 2 months ago 3 Members · 3 Replies
  • Michael Phillips
    July 10, 2009 at 3:09 pm
    Try opening the audiosuite window from the tools window first. Select in-out of entire timeline, then do a render. The try again for QT.
    Michael
    Michael Phillips
  • Cesar Barrantes
    July 10, 2009 at 6:55 pm
    I actually already tried opening up the audiosuite window, selecting in-out of the entire timeline, then doing a render. Still receive the scanning for unrendered audiosuite plugins message.
  • Hugue Loiselle
    July 9, 2010 at 8:36 am
    Here’s the solution
    This is most likely caused by bringing a user profile over from a previous version of the editor. The solution is to create a new user profile and try to export out again.
    hope it helps
    Hugue
    Hugue
