Activity Forums Apple Final Cut Pro Legacy scaling&conform in fcp5
  • scaling&conform in fcp5
    Posted by Joe Editor on February 15, 2007 at 3:56 am
    what are the drawbacks (if any) of dropping a regular old mini-DV 29.97/4:3 clip into a 23.98/16:9 sequence and scaling the clip to 133%.
    to me it looks just as good as scaling it in after effects but i could be wrong.
    what is the best way to do this?
    thank you for your help.
    Jerry Hofmann replied 19 years, 6 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    February 15, 2007 at 1:50 pm
    If you don’t see a problem, I’d suggest you probably don’t have one… I haven’t looked at this comparison side by side, but I’ll wager it’s close. There is a setting though you should be using in FCP… select your sequence, and type cmd+zero to open it’s settings. in the processing tab, select high quality for the motion filtering quality. This will improve the scaling you’re doing.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
