Activity Forums VEGAS Pro scaling trouble
  • scaling trouble
    Posted by Kenneth Tolaas on January 20, 2009 at 11:21 pm
    Hello, I got a .mov-file from a guy that has been exporting it wrong. it should be 16:9 dv pal, but there some letterboxing or whatever you call it, so that I need to scale it.
    there is also these big stripes, like very big interlcing-progblems.
    Is there anyway I remove these big “interlacing-stripes”
    It’s not just to have it correct in the “interpret footage”
    I can use After effects, premiere or sony vegas, whatever works…
    thanks for any help,
    -Kenneth =)
    John Rofrano replied 17 years, 7 months ago 2 Members · 1 Reply
  • John Rofrano
    January 21, 2009 at 4:06 am
    Those vertical bars are called pillar boxing rather than letter boxing which is horizontal bars. This means the 16:9 aspect is lost. You can’t get it back with just scaling; you’ll have to stretch it which will look terrible. Also the bad interlacing is not normal interlacing artifacts, meaning it looks like it is beyond repair. I would have him export it correctly. That footage looks unusable to me. Hopefully someone else here will have a better answer.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
