Activity Forums Adobe After Effects Scaling Multiple Layers at different times
  • Scaling Multiple Layers at different times
    Posted by Wesley Kelemen on July 22, 2016 at 12:54 pm
    Hey Guys
    I basically have one of those facebook videos that is a text slide show. It’s quite long. I completed it but now the client wishes to scale the text on each layer. So something like %100 – maybe %110. Now I could go in and add a adjustment or null to each one and parent but is there a way to scale them from one effect?
    So each text layer would scale %10 during it’s life.
    Thanks guys for any help
    Wesley Kelemen replied 10 years, 1 month ago 3 Members · 8 Replies
  • 8 Replies
  • Walter Soyka
    July 22, 2016 at 3:10 pm
    [Wesley Kelemen] “So each text layer would scale %10 during it’s life.”
    You can do this by adding an expression to the text. Alt+click the Scale property stopwatch and enter the following:
    value*1.1
    Once you’ve done this to the first text layer, select its Scale property in the timeline panel, then Edit > Copy expression only. Then you can multi-select the other text layers and paste.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Wesley Kelemen
    July 22, 2016 at 3:29 pm
    Thanks I’ll take a look
  • Wesley Kelemen
    July 22, 2016 at 3:30 pm
    I think this might be my best option. Seems pretty simple thanks a lot! Saves me mucho time
  • Wesley Kelemen
    July 22, 2016 at 3:52 pm
    I put value*1.04 in and nothing happens. The scale percentages turn red and thats it. No error just nothing happens
  • Walter Soyka
    July 22, 2016 at 4:36 pm
    You’re increasing the scale by 4%. For smaller initial scale values, the difference may not be noticeable. Increase that number as needed.
    Walter Soyka
  • Wesley Kelemen
    August 1, 2016 at 1:05 pm
    Still can’t get it to work… I’m not too familiar with expression but I alt click the stopwatch which opens up expressions..
    then I skip to the next line and paste value*1.1. Press Enter then go to preview
    Then nothing happens..Am I missing something?
  • Kalleheikki Kannisto
    August 1, 2016 at 1:12 pm
    Delete the expression that gets inserted automatically and replace it with the new one.
  • Wesley Kelemen
    August 1, 2016 at 1:15 pm
    Still nothing….
