Activity Forums Maxon Cinema 4D scaling keyframes as in After Effects
  • scaling keyframes as in After Effects
    Posted by Sneakerpimp on February 10, 2007 at 8:18 pm
    Hey people, is there a way to easily scale the distance of keyframes in the C4d timeline – similar to after effects? (I think it’s Option-drag on the Mac in AE) I know about the time track thing but I’d rather just set the numerous keyframes correctly. Any thoughts. I’m using v9.6.
    thanks
    Sneakerpimp replied 19 years, 6 months ago 2 Members · 2 Replies
  • Mikeh64
    February 11, 2007 at 12:02 am
    select the range of keyframes you want to scale – there will now be a pink line at the top of the timeline with red nubs at each end above the range of keyframes – just click and drag either red nub
  • Sneakerpimp
    February 11, 2007 at 7:01 am
    thank you very much for your reply. I was just about to do this manually for about 25 different objects and on a fluke pulled the red handle and got it. But again thanks so much for your relply.
    Sometimes its difficult to find answers like this in the manual if you don’t know the correct term to search for.
