Activity › Forums › Adobe After Effects Expressions › Scaling Exp simpl/ cant find what i want
  • Scaling Exp simpl/ cant find what i want
    Posted by Matt Stoltz on April 27, 2007 at 5:36 am
    Hi all –I need and expression that will scale the photo from its current scale size–I have 161 pics and they are 6 seconds a piece each one is about 22%,25% big and I want each one to scale about 10%.
    id like to do one expression with all-(ex like if i use a null and I link all 161 pics to that null and they all scaled 10% of their size
    thanks
    Filip Vandueren replied 19 years, 5 months ago 2 Members · 1 Reply
  • Filip Vandueren
    April 27, 2007 at 12:36 pm
    You’ll need to add an expression to each layer seperately.
    An expression in one property can’t affect the value of another…
    Something like this would work:
    startvalue=value;
    endvalue=value+[10,10];
    linear(time,inPoint,outPoint,startvalue,endvalue);
    apply to one layer,
    then goto edit -> copy expression only
    select all other layers,
    paste.
    you can also try
    endvalue=value*1.1; or some other value
    for easier updating, link the actual value ([10,10] or 1.1) to a slider on a Null object, that way you can tweak it without changing 160 expressions.
