Activity Forums Adobe After Effects Expressions scaling a solid depending on the time
  • scaling a solid depending on the time
    Posted by Yair Neumann on January 18, 2011 at 12:02 pm
    Hello,
    I would like to scale a solid only on the Y axis when the time line/frames(doesn’t matter) reaches a certain number and than have it scale back.
    my final comp is to have a circle of solids scaling one after the other back and forth.
    this is what i have so far:
    thank your for your help
    scaleY=thisComp.layer("Null 1").effect("scaleY")("Slider");
    m = timeToFrames()%thisComp.layer("Null 1").effect("FRQ of scale")("Slider");
    maxscale = 40;
    minscale = 0;
    startFade = m;
    fadeDur = 1;
    if(m==index) {
    [value[0],value[1]+linear(m,startFade,startFade+fadeDur,maxscale,minscale)
    else{
    [value[0],value[1]];
    Dan Ebberts replied 15 years, 7 months ago 2 Members · 1 Reply
  • Dan Ebberts
    January 18, 2011 at 8:38 pm
    Play around with this:
    numLayers = 8; // number of layers participating
    cycleDur = 10; // total cycle duration
    scaleDur = 1; // time to scale up and down
    scaleMin = 0;
    scaleMax = 40;
    seg = Math.floor((time%cycleDur)/(cycleDur/numLayers));
    y = 0;
    if (seg == index-1){
    t = time%(cycleDur/numLayers);
    if (t < scaleDur/2)
    y = linear(t,0,scaleDur/2,scaleMin,scaleMax)
    else
    y = linear(t,scaleDur/2,scaleDur,scaleMax,scaleMin);
    value + [0,y]
    Dan
