Activity Forums Adobe After Effects scaling a shape layer and image (via Luma) at ther same time.
  • scaling a shape layer and image (via Luma) at ther same time.
    Posted by André Macedo on July 23, 2020 at 8:54 pm
    Hi there,
    i have an issue that i am not really managing to solve.
    here´s what i have:
    1) I created a circle (with elipse tool) wich is a shape layer that “masks” an image via trackmatte LUMA.
    2) Then i downscaled the image so it fits the size of my circle.
    3) To this shape layer i gave scale and opacity attributes – So now it reveals the image, scaling and fading away perfectly. All good.
    The thing is that i need to have the image scaling along with my circle shape layer aswell.
    I tried parenting with pickwhip the scale parameter of my image to the scale parameter of the shape layer, but the image looses its initial scale (explained on point 2). I need them to scale all together hand in hand.
    What should i do? any advice on how to solve it?
    Thank You !
    André
    André Macedo replied 6 years, 1 month ago 2 Members · 2 Replies
  • Filip Vandueren
    July 23, 2020 at 9:58 pm
    If you animate the ellipse’s size with it’s layer’s scale property
    (= not the Size Parameter of the Ellipse, and not the Scale of it’s Shape Group).
    -> Then normal layer-parenting will work as expected and you will not need an expression
  • André Macedo
    July 23, 2020 at 11:07 pm
    Hi Filip,
    thank you,
    i followed your suggestion,
    i scaled the ellipses layer scale property (the “main” layers transform attribute in other words), instead of the size parameter property of the ellipse – and then parented the image scale property to the ellipse´s layer scale property — again my image blows up in scale – its like the parenting doesnt care about my image size (wich is downscaled inside the circle).
    thank you filip
