Activity Forums Adobe After Effects Scaling a mask as rotating and adding keyframes
  • Scaling a mask as rotating and adding keyframes
    Posted by Murat Ozturk on December 25, 2013 at 1:24 pm
    Is it possible scaling a mask while rotating it? If so, how can I add some keyframes as well. I want to add some key points as I am doing this operation in my composition so that I will be able to have some mask transitions done. Any help would kindly be appreciated.
    Thanks in advance.
    Murat Ozturk replied 12 years, 8 months ago 3 Members · 3 Replies
  • George Goodman
    December 26, 2013 at 5:02 pm
    I’m not exactly sure what you’re trying to do, but it sounds like you may be looking for the mask path and/or mask expansion properties.
    “|_ (°_0) _|”
    Sincerely,
    George
  • Erik Waluska
    December 27, 2013 at 1:51 am
    If I understand your question, you want to expand the mask properties and add a keyframe for the mask path. Move forward in time to where you want the second keyframe, then with the mask selected hit Ctrl/Cmd + T to enter transform mode and then you can grab the transform handles and scale and rotate the mask. Hold Shift to scale uniformly, Ctrl/Cmd to scale from the center. You can also transform 2 or more vertices instead of the whole mask, just select the points and hit Ctrl/Cmd + T.
    You could also animate the mask expansion property as George mentioned above.
    Erik Waluska
    EAWmedia
  • Murat Ozturk
    December 27, 2013 at 8:32 pm
    Thank you so much Erik; you and George showed me the way, then done it so. Really appreciated.
    Regards,
    Murat
