Activity Forums Adobe After Effects scaling a layer with out scaling the mask
  • scaling a layer with out scaling the mask
    Posted by Anonymous on May 3, 2007 at 4:17 pm
    Is there a simple way to scale a layer with out scaling the masks?
    Anonymous replied 19 years, 4 months ago 4 Members · 4 Replies
  • Jason Griffith
    May 3, 2007 at 4:44 pm
    Can you copy the mask to a pre-comp of the layer and scale the source of the pre-comp?
    “An Unexamined Life Is Not Worth Living” – Socrates
  • Jeremy Rowell
    May 3, 2007 at 5:16 pm
    You should be able to precompose the layer and do your scaling then mask the precomposition…
  • Trevor Ward
    May 4, 2007 at 1:44 pm
    About using track mattes: Is there a way one sold can be used as a track matte for several layers?
    I have 3 objects that I move from “behind” a spot in my video. So I can create a square that will be used as a track matte. But I have objects that I want to come from “behind” this spot. I had to duplicate the matte layer 2 times and then have 3 objects and 3 track mattes.
    -trevor ward
    http://www.redeyevideoproductions.com
    orlando, fl
  • Anonymous
    May 4, 2007 at 6:06 pm
    I’m working with 3d layers so I didn’t really want to precomose. I decided it was easaiest for me to just scale the layers and then scale the masks. thanks for the help though.
