Activity › Forums › Adobe After Effects › Scaling a comp?
  • Scaling a comp?
    Posted by Shawn Bossick on February 13, 2008 at 6:18 pm
    When I scale a comp up or down even by as little as 1% I lose quality, slightly blurry, not as sharp, etc. How to avoid this?
    Thank you very much in advance!!!
    Shawn
    Shawn Bossick replied 18 years, 7 months ago 2 Members · 2 Replies
  • Darby Edelen
    February 13, 2008 at 7:00 pm
    [Shawn Bossick] “When I scale a comp up or down even by as little as 1% I lose quality, slightly blurry, not as sharp, etc. How to avoid this? “
    Are you scaling a pre-comp or footage? If you’re scaling a pre-comp try enabling the ‘Collapse Transformations’ switch on the pre-comped layer.
    Here’s info on where that switch is if you have trouble:
    https://livedocs.adobe.com/en_US/AfterEffects/8.0/WS3878526689cb91655866c1103906c6dea-7e60.html
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Shawn Bossick
    February 15, 2008 at 5:41 am
    I thank you for your response, but no that didn’t work. Maybe I should have mentioned I’m using AE 6.5, don’t know if that makes a difference or not, but this button you spoke of, I went through all the info from the link you sent and I see where the button should be but is NOT in my version of AE. Anyone else?
    Thanks all!
