Activity Forums Adobe Photoshop Scaling
  • Scaling
    Posted by Michele Wheeler on October 6, 2008 at 3:53 pm
    A couple of days ago I lost the ability to scale text, boxes and art… by dragging to fit an area. For example the text does not have a bounding box so I can’t click and manually drag out to fit an area. Instead it has a blue line underneath the text. I have re-installed CS3 Suit… hoping this would solve the problem, it did not. I am assuming it is a setting issue but I have searched and can’t find a solution. Has anyone had this problem and if so please help?
    Keith Thomason replied 17 years, 11 months ago 3 Members · 2 Replies
  • Kelly Johnson
    October 7, 2008 at 3:00 am
    I had this a couple of times with CS2, never w/CS3.
    Trash the preferences. Unless you used an un-installer, the old preferences were still there even when you re-installed.
    I always just search for any files with com.adobe and then look them over in the finder to see if they are ones to trash.
  • Keith Thomason
    October 7, 2008 at 5:31 am
    You didn’t accidently hide your bounding box did you? Go under view and see if you can “show bounding box”.
