Activity Forums Adobe After Effects Scale Mask to distance between nulls
  • Scale Mask to distance between nulls
    Posted by Michael Neumann on December 12, 2013 at 6:01 am
    I am not very skilled when it comes to After effects and I now ran into a small problem:
    For now the position of the (Plexus) circle between her hands is calculated with an expression.
    I was wondering if there is an expression I can use to let the circle get scaled by the measured distance between the two nulls. Right now everything is keyframed manually and it looks kind of cheesy.
    Can someone help me with that?
    Michael Neumann replied 12 years, 9 months ago 2 Members · 2 Replies
  • John Cuevas
    December 12, 2013 at 2:40 pm
    You might try the https://forums.creativecow.net/adobe_after_effects_expressions“>Expression Forum, someone might have a way of working it out for you. The guys there are just incredible at figuring this stuff out.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Michael Neumann
    December 12, 2013 at 11:46 pm
    I reposted it to AE Expressions. So this entry can be deleted pls.
