Activity Forums Adobe After Effects Expressions scale like in CTRL+ Y slider control
  • Dan Ebberts
    April 24, 2007 at 7:12 pm
    Nope. You can’t alter a solid’s dimensions with an expression. You should be able to do what you want using scale, if you set it up right. Hard to say what you’d have to do differntly though, without more details about your setup.
    Dan
