Activity Forums Adobe After Effects Scale Expression with inertia bounce – start from zero
  • Scale Expression with inertia bounce – start from zero
    Posted by Justin Alexander on October 20, 2011 at 10:14 pm
    Hi everyone,
    I have been using these forums for a long while and found them to be immeasurably helpful.
    What I am trying to do now is get a layer to scale in and scale out at its in and out points, along with a bit of an inertia spring.
    I have used one of Dan Ebberts scripts from one of the posts here and modified it a bit to work at in and out points.
    The problem I am having is that the layer needs to be constantly re-sized to get somewhat reasonable results. Most of the time it bounces out OK although it never seems to really get to 0% scale. The in point is the one that doesn’t work properly though. Rarely can I get it to start at 0% scale. I have to have the layer scaled to the right size and tweak the ‘Scale’ setting in the expression. I normally have the variable set to sliders but have replaced them with my default settings here for easier dissecting.
    I have the following script on a solid scaled at 40% in a 1050 x 576 comp. Solid was made comp size as I want this to work at any scale.
    S =100; // Scale
    A =20; // Amplitude
    F =20; // Fequency
    to = outPoint - time;
    ti = time - inPoint;
    inTrans = x=S*(1-Math.exp(-A*ti)*Math.cos(F*ti));
    outTrans = y=S*(1-Math.exp(-A*to)*Math.cos(F*to));
    value+ [inTrans,inTrans] + [outTrans,outTrans];
    What I want to accomplish is to have the layer start at 0& scale and ramp up to whatever I set before applying the script. Then have a bit of inertia bounce that can be adjusted for intensity and length. At the minute the inertia bounce is working beautifully, I just need the scale to start and finish a 0%.
    Then I want to be able to save it as a preset and have it save me hours of time over the next couple of years.
    Really hope that I have made sense and that someone is able to tell me where I have gone wrong.
    Regards
    Justin Alexander
    Justin Alexander replied 14 years, 11 months ago 2 Members · 2 Replies
  • Roland R. kahlenberg
    October 21, 2011 at 5:51 am
    Justin, why don’t you post this in the COW’s AE Expressions Forum? Dan does drop by here on occasions, but you’re more than likely to get a reply from him there.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia.
  • Justin Alexander
    October 21, 2011 at 7:41 am
    Thanks for the heads up.
    I hate making newbie misstakes
