Activity Forums Adobe After Effects Expressions “scale” depending on “position”
  • “scale” depending on “position”
    Posted by Gunnar Kordestani on January 31, 2009 at 7:15 pm
    hi everybody,
    I have a rolling title here. Each line is a single textlayer.
    I would like each line to get bigger when being in the middle of the screen (x=720, y=540 in this case). Getting smaller, when getting/coming to/from the edges.
    I wonder what an Expression for the “scale” property should look like.
    any suggestions out there?
    thanks a lot
    Gunnar
    Dan Ebberts replied 17 years, 7 months ago 2 Members · 3 Replies
  • Dan Ebberts
    January 31, 2009 at 8:57 pm
    Something like this should get you started:
    minScale = 100;
    maxScale = 200;
    centerY = thisComp.height/2;
    dist = Math.abs(toWorld(anchorPoint)[1] – centerY);
    s = ease(dist,0,centerY,maxScale,minScale);
    [s,s]
    Dan
  • Gunnar Kordestani
    February 5, 2009 at 6:34 am
    minOpac = 50;
    maxOpac = 100;
    dist = Math.abs(toWorld(anchorPoint)[1] - centerY);
    s = ease(dist,0,centerY,maxOpac,minOpac);
    [s,s]
    hi Dan,
    thanks. that exactly does it. As I am trying to understand whats going on I experimented a little. Trying to use it for other properties.
    When using it for “Opacity” I get an error “Expression result must be of dimension 1, not 2. Error occured in line 0.”
    I don’t get it. What’s the problem here? Of course I have to admit, that I am not relly too experienced with expressions and need to build up with the basics still.
    thx
    Gunnar
  • Dan Ebberts
    February 5, 2009 at 6:40 am
    This should do it (haven’t tried it, but it looks right):
    minOpac = 50;
    maxOpac = 100;
    Dan
