Activity › Forums › Adobe After Effects Expressions › Scale change loop
  • Posted by Joel Gamble on September 5, 2011 at 1:48 am
    I am trying to figure out an expression that will scale an object from 105% to 95%, and then from 95% to 105%, continuously through the animation. Each scale (e.g. 95% to 105%) would last 1 second.
    I can’t figure out how to loop the effect. I know how to do this in Java (using if statements, but the syntax isn’t the same in javascript. Below are the lines I have figured (not much, I know…)
    Any help would be greatly appreciated!
    Thanks in advance,
    JG
    linear(time, 0, 1, [105,105], [95,95]);
    linear(time, 0, 1, [95,95], [105,105]);
    Dan Ebberts replied 15 years ago 2 Members · 1 Reply
  • Dan Ebberts
    September 5, 2011 at 3:44 am
    This should work:
    t = (time-inPoint)%2;
    if (t < 1)
    linear(t, 0, 1, [105,105], [95,95])
    else
    linear(t, 1, 2, [95,95], [105,105]);
    Dan
